esh
I have wanted a Waeco (Dometic) CF-11 for years to use as a center console or otherwise handy in-cab fridge. Dometic prices are starting to reach what 40-50L fridges were back in the day, but Amazon has that wonderful Recommended purchase bar that randomly appears for other suggestions. The first that showed up was an "Alpicool" (I don't think many of these names really matter). It is a legit mini-sized Danfoss looking compressor driven fridge freezer. They are generally Engel-looking units in plastic, and about 1/3 price of the smaller capacity Dometic.
After looking and verifying what I found wasn't a thermoelectric unit (can tell because those tend to say -10 or 20, or +10/20 etc degrees somewhere in the description), I ended up getting a "Ausranvik" blue unit, mostly because the lid has a latch and it came with both AC and DC ps/connectors.
My first impression is that is decent with average build quality- not cheap, and not certified extreme expedition approved. The lid orientation is good for how I intend to carry it, and it also orients the vents so that there is a less chance of them being blocked. Compressor sounds like a small version of my Waeco CF-40 or Dometic CFX-50 Danfoss compressors, but the fans are on the cheaper side or just not well dampened. I haven't done a draw test, but it took an hour to get from 75F to 32F on hi setting. There is an eco mode as well. Temperature control allows from -4F to 50F, and there is low/mid/high cutoff for battery. High is the conservative cutoff. It does run more than I expect, but that also may be I have it sitting on my desk for work next to me, and the bit more noise from proximity and fans over the larger Dometic I have.
Anyways, it seems like a good purchase and gives easy access to a surprising amount of space to snacks and drinks. Time will tell, but likely would purchase again at $185. https://www.amazon.com/gp/product/B07KSPY3KQ
