4x4 7.3 Diesel Super C Bigfoot RV
space cap
1998 Oakland Super C Diesel 30MH29G Garage Model. Located in BC Canada, $68,000 CAD
img_3525-jpg.554829
Oakland was the premium line of Bigfoot, these are not made anymore and this is a very rare RV.
7.3 liter V8 turbo diesel powerstroke with only 65,000 original km.
- Brand new coil sprung Dana 60 solid front axle
-4WD hi and low range - full conversion was just done 2 months ago
- New Front coil springs, 6'' lift in front and 5” in back
-Rear airbags with lift spacer
- 4 new Bilstien 5100 Shocks
- All new steering linkage, front brakes, driveshafts, transfer case, ball joints, wheel bearings, tie rod, drag ling, pitman arm etc. complete new front end
-Hellwig over sized front sway bar
- 285/70/17 Toyo M55 on front with full size matching spare, 17x9 wheels
-255/85/16 Toyo M55 on the rear, 16x6 wheels
-Nightrider 32'' curved LED light bar
-Custom 2'' front hitch receiver
-Line X bumper and grill
All parts are brand new and haven't been used yet.
-Maxtrax recovery boards
-Gemstone kinetic recovery rope and soft shackles - 33,000lbs
-Warn VR 12 EVO with Gemstone synthetic line - 23,000bs
-Warn winch carrier so winch can go in front or rear receiver
-Wiring for winch run front to back and has a shutoff switch for rear wiring
-Snatch block, tree saver, hitch shackle, D rings, etc. lots of recovery gear
- LED tail lights and cab marker lights
-3 solar panels, charge controller, 4 batteries, 2000W inverter/converter
-Cubic mini wood stove
-2 diesel air heaters
-Froli star bed package
-2 additional brand new dual pane windows
4WD conversion was professionally done by Sportsman Light Truck in Kamloops BC who fabricates the Clydesdale 4x4 van conversion.
This is possible the ONLY Bigfoot 4x4 RV in Canada with a diesel, garage, and 4WD! They're made in British Columbia Canada! No one built a better quality rig then they did! The RV, 4x4 kit, wood stove, solar was all made in Canada!
Only reason for selling is that's how it goes, life changes. It's in such nice condition everywhere. It's been mechanically inspected, RV inspected. I am planning on renovating the interior this winter. So buy now and leave as is or renovate to your liking. Price will go up as work progresses and spring hits. Off season pricing right now. A new Class C, if you can find a diesel, and if you can find a 4x4 would cost way more the $150,000. And this RV has superior construction compared to new rigs.
This winter ready rig is fully equipt with every factory option, thermal pane windows and skylights, heated and enclosed undercarriage, GARAGE MODEL, aluminum superstructure, auxiliary rear heater, motoraid hot water heater,8 legal seat belts. This rig weighs 11,500 lbs. The garage is large enough to carry a quad, sled, bike, etc. Full factory specs are listed here,
https://www.bigfootrv.com/docs/brochures/2000 Brochure.pdf
Bigfoot Brochue 2000
6 3000 Series Campers The Bigfoot 3000 Series Truck Campers offer the same patented Fibercore® Wall System as the 3000 Series Motorhomes.The roof and floor are also constructed using
www.bigfootrv.com
workerdrone
Part time fulltimer
Needs more pics! Should be illegal to post an ad for an RV with a woodstove and not show the setup ;-)
GLWS, we miss our Bigfoot
Supreet.dhaliwal
