96' Desert Dune SR5 4X4 w/ 146,500 miles
Located in Wake Forest, NC (near Raleigh)
Pw, pdl, pm, moonroof, cold a/c, hot heat
Mods list-
Toytec Ultimate Kit w/ superflex coils & 650lb coilovers
SPC UCAs
Toytec Diff drop
SCS F5 wheels (5)
315/70/17 Mickey Thompson Deegan 38 (5)
1'' Toytec Bodylift
Hayden 210 transmission cooler mounted inline
inline magnetic transmission filter
ECGS 4.88 swapped diffs
ECGS ARB Rear Airlocker/ 4.88 3rd
ARB mini comp mounted in rear cubby
Lotus Rear control arm mount skids
Shrockworks front bumper w/ Baja Designs Squadron Pro R fogs
Stubbs HD-SKO w/kickout sliders
CBI Hybrid Rear bumper with swingout and hi-lift mount
Dual battery setup with Ballistic Fab battery cage
Red & yellow top optima 34/78 batteries both new in November/20
Blue Sea ML-ACR battery charging relay
Xantrex 1000 SW Inverter under driver's seat
Blue Sea Fuse block 12- circuit under hood
Uniden 520 CB in ashtray holder
Warn 9.5xp-s winch and wireless remote
Walbro 190 fuel pump
Big 3 mod
CS144 alternator swap
AEM trans. Temp gauge
Bilstein rear 5100 shocks
Weather tech floor liners
Sankei 555 ITREs
Tundra rotor/ pad/ caliper conversion
Tacoma antenna whip mod
TBU at 101K
HD SB links front set
At 142305 it got OEM valve cover gaskets, plugs, wires, tube seals, pcv valve, etc
What comes with the rig-
New oem belts set, rad hoses, all wheel studs, LBJ bolts for spares (4), fuel filter, (2) gallons toyota red coolant, case of toyota ATF
96 full service paper manual
Off grid engineering ML-ACR wiring harness
35mm hub socket
Set of Napa Gold CVs
Issues-
ARB seal in rear 3rd needs to be replaced. East coast gear may or may not warranty it.
ARB compressor switch is broken. Needs a new rocker switch.
Front fender damage
Electrical stuff- it needs a Auxiliary light wiring harness and cb wiring for these to work.
Some tears in the driver's seat
The body has small dings and pinstripping from use.
Runs and drives great. 80 on the highway with one finger on the steering wheel. Plenty of power. I daily drive it, go to the mountains some weekends for light wheeling. No rust. I have a clean and clear title in my name. Have the original window sticker and books. Winch works good. Would trust it to drive anywhere.
I'll post more/ better pictures this weekend.
$9.500 cash please call or text Ben @ 919-999-6791. Thanks!
Mods list-
SPC UCAs
Toytec Diff drop
SCS F5 wheels (5)
1'' Toytec Bodylift
Big 3 mod
Sankei 555 ITREs
TBU at 101K
35mm hub socket
Issues-
Front fender damage
