Does anyone know how to make contour lines easily visible on the Baja540. Mine are very very faint. I 'm using MapCreate7. The elevation numbers and everything else seem to be ok. Thanks, Steve
Thanks, Crawler.
This helped a little bit. What is interesting is the slight improvement came when I went to low contrast. Not what I was expecting. The definition is still nowhere as nice as on the PC. Thanks, again. Steve
BoxCar, mine is exactly like yours. I havn't had time to see if there is a way to improve the contrast beyond what was already suggested. I will post back here if I find a solution.
Change it over to night mode they show up much better, i will have to play with it to remember where it is at to change it, i run mine in night mode all the time.
