kraven
Hegelian Scum
The truck:
The challenge: minimal budget, maximum fun.
Criteria: Reliable, able to tow, goes in the snow, and does road trips.
Why? I made several mistakes.
1. I attended the Overland Expo last year. Big mistake on my part. Now I want to do some overlanding.
2. I know how to work on stuff
3. I bought a house, finally settling down after being a rolling stone for my whole life, and I need to maintain it. That means I need a 4wd pickup.
4. I read a bunch of threads on here, and Zach Bowman's (leftoflucky on here) series of stories on The Drive about selling his house and living on the road.
5. Everyone needs a good 4wd and I didn't have one.
I did the only thing I could do when a man is looking to blunder into a huge mistake like buying a piece of crap vehicle or pet sitting for a swinger party. I put an ad on Craigslist. Project 4wd truck wanted. Ford/Chevy/Toyota.
Guy with a Dodge calls. It's a few miles from a Chevy I'm going to look at, so why not?
It has rusty wheel arches, solid frame, "blown head gasket" (2nd gen Ram gasser for "cracked head"), and the wheel/tire combo is the product of a couple of "oh ****!" moments that surely bent at least two rims. Nothing is tweaked, the axles are solid and not bleeding, the wiring isn't hacked too badly. Typical Southern Appalachian poverty indicators of cheap speaker wire run willy nilly to door speakers, body dents, dings, clamp on battery cable ends, interior that smells like a Ronco smokeless ashtray in constant use since your Aunt Mildred bought off a tv commercial in the 70's, etc. Good bones, crappy upkeep. Just what I wanted. Except its a Dodge. I'm a Ford guy. Really, I'm a Toyota guy. But I have more experience working on Ford because my Toyota stuff is so reliable.
The good: I got it cheap, less than a grand. So, it's practically a winner already. It's a pretty well equipped truck and it's solid. The window sticker came with the paperwork and owner's manual. It was optioned with the tow package and anti-slip diff, so heavy duty cooling, whatever that is, and maybe a clutch diff to rebuild instead of buying an LSD. It was ordered with the 5.9, so plenty of beans for towing. High amp alternator option was added, so plenty of juice for stuff. The A/C and heat work, miracle of miracles. The tailgate shuts, which means the bed isn't tweaked, which means the frame isn't tweaked. 4 actually good tires with nearly new tread depth.
The Bad: engine is shot, trans probably is on its way out, and I haven't really looked at the t-case aside from using 4 low to move it around. Not that bad, it's what I expected. Rear bumper is rotten. Wiring needs a good unforking. Cab corner rust I can't live with because it looks awful. I'm probably going to find pebbles of meth as I take the interior apart to gut it and clean the nicotine out of it.
Not looking forward to that. Front axle ends make noise in 4wd.
The plan: Get it running, driving, stopping, steering, and articulating. Do the standard stuff: sleeping setup, bed topper, and skid plates. Stay on budget (no, srsly).
Maybe:
4bt swap
Air bags for the rear
LED's
Roof rack
Sun is rising and I'm going to start a compression test to see if it's a rebuild or a head gasket. I wanted to write all this down before the blue morning light of day 2 with this pile damps my enthusiasm and will to live.
Maybe:
4bt swap
LED's
Roof rack
